hotpoint WF340
  • #28196
    comptonappliances
    CUST HAS JUST INFORMED ME THE MACHINE STARTED TO WASH AND AFTER A MINUTE THE ON/OFF – REDUCED CREASES-RINSE HOLD AND MINI LOAD LIGHTS ARE FLASHING CAN U PLEASE TELL ME WHAT THIS FAULT CODE MEANS THANKS.
    #217333
    DentedPorsche
    Re: hotpoint WF340
    Sorry, I don’t know the layout of the controls but you’ll find the codes on page 3 of known error codes.
    Brian 😀
    #217334
    comptonappliances
    Re: hotpoint WF340
    CHEERS BRIAN SHOWS AS HEATER RELAY FAULT
    #217335
    Re: hotpoint WF340
    It means your CAPS LOCK IS STUCK😉 it is also the dreaded 8 flash problem, could be relay on PCB, bad connections to module or NTC, faulty pressure switch, etc,etc.
    Jim. 😥
    #217336
    comptonappliances
    Re: hotpoint WF340
    😆 THANKS JIM 😆 i know heater is open circuit will check ntc when i return
