Hi, I have a hotpoint wf340 washing machine and in the last couple of days when I have tried to use it,
It seems to work fine but half way through a cycle it just stops with no lights illuminated as if the fuse has blown but I haave check the power and there is power going to it. After a couple of hours the machine will come back on but does not continue the cycle. Any help would be very grateful Roisin
Hi, Thanks for your reply I have called a electrician who has just checked the sockets in the kitchen and he is saying they are fine as it acts just like the power has gone from the washing machine. I just wondered if there was anything I could do to find out if its repairable or will I need a new machine. Many Thanks Roisin
Hi Helo, You were right he has just found that the actual switch on the plug socket was shorting out so its a new switch socket and not the washing machine….phew thanks for your very fast replys….Roisin
