hotpoint wf340p
Viewing 15 posts - 1 through 15 (of 15 total)
  • #23217
    hotpoint wf340p 45149934
    machine start fills start to turn ok around 30 secs later (approx) all light com on then go off macine resets and starts again does not like responding to buttons
    assume it is a board gone unless anyone can come up with a silly fault but this machine has 2 boards the indesit style prog down at bottom and the display control panel that also has a chip on it
    any ideas before we scrap it 14 months old ❓
    phil59
    Re: hotpoint wf340p
    scrap it unless its in some sort of display mode for shop demos 😕
    #197371
    roy1
    check motor plug & loom common fault.
    Roy
    #197372
    Re: hotpoint wf340p
    phil59 wrote:scrap it unless its in some sort of display mode for shop demos 😕
    Why???
    It is still under Hotpoint’s 5 year parts warranty, admittedly the labour is a bit high at just under £90.00, do the decent thing if this machine belongs to a customer of yours and tell them this. I always do, it helps me sleep at night.
    Re: hotpoint wf340p
    have already mentioned 5 year part warranty to customer she was worried that she had not registered the machine when new but lokking through the leaflets you could do it by post so i told her to say she sent it
    most of the time i tell about 5 year warranty if they are going to sell s**t they deserve the comebacks
    Re: hotpoint wf340p
    As long as they have a receipt, Hotpoint/Indesit will honour the 5 year g/tee, we all know the ‘registration’ process is mainly just a way of getting your details so that they can bombard you with mailshots pushing extended warranties.
    Even the date code on the door should suffice, I am 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain that the Indesit Company would not refuse to honour a warranty because the machine was not registered, as long as you can prove D.O.P .
    Tony_EMW
    Re: hotpoint wf340p
    Send us the board for repair £34.90+vat inc return postage. Please include a note of the model no. Tony 01159652118
    #197376
    pmb
    Re: hotpoint wf340p
    One of my customers rung up while i was there and just gave the model and serial numbers over the phone and that was enough which was quite good i thought if only all things were that easy 🙂
    #197377
    WhiteVanMan1
    Re: hotpoint wf340p
    Just a quick note. The decision on D O P ‘s is left to the Hotpoint engineer that turns up. If your date code is in time, he will repair without further problem, UNLESS you get one that has some sort of problem and likes to make life awkward.
    Steve
    #197378
    fasetester
    hotpoint aquries
    hi guys went to see a hotpoint aquries mod wf 430p 1300 problum was when it came to empy out and spin it stopped full of water empyed out water and removed pump rag stuck in pump removed hoses and checked seems ok but when the machine was restarted just keeps pumping out and flashing time saver light and on off light the on off light is flashing very fast does the machine need reset and if so how do i reset it or is there another problum thanks for any help fasetester. 😕
    #197379
    Re: hotpoint wf340p
    You need to identify the time saver light by number from the top down, then use the information in the known error codes thread.
    effzedarr
    Re: hotpoint wf340p
    Nice to see washers have come on a bit, isn’t it !? :rolls: :rolls:
    Chris..
    #197381
    fasetester
    Re: hotpoint wf340p
    thanks for your reply it is the fourth light down the time saver light jim do you think the machine just needs reset as the problum was a blockage after that the owner said the washed rugs in the machine i said the have bother washing clothes never mind washing rugs then when i went back to reset the son said it was working ok but when i contacted the mother she said it was not and was not paying and was buying a new machine so i told her if she did not want to pay that i would take the machine as payment as it was only 2 yrs old have not heard from her since last week so i rekon the retset the machine how do you get people to pay up as i am straight with people and said i would try and get the machine going for her 😡 fasetester
    #197382
    Re: hotpoint wf340p
    fasetester wrote:thanks for your reply it is the fourth light down
    For future reference that is error code F01 which is the motor triac on the board failed. 🙁
    fasetester wrote:how do you get people to pay up
    You can’t, in fact in this case I would simply put it down to experience gained if I were you. But next time you get one of these machines to look at, print off a copy of the error codes thread first. 😉 That is invaluable information that will save any headscratching in the customers home, and will hopefully lead to a faster diagnosis and a happy paying customer. 🙂
    #197383
    fasetester
    Re: hotpoint wf340p
    thanks for your reply martin the machine seemed to be tumbling ok before i removed the pump and the blockage do you think the blockage could have caused the triac on the board to blow is there any way to test the board i covered the board and the motor with a carrier bag to stop them from getting wet what a place to put a board straight under the pump so holding in the start button for 3 sec would not have reset the program fasetester 🙁
