Hotpoint WF430
  • #62495
    AMS
    Hi all,
    I’m ashamed to say I made a bit of a balls up today and I’m hoping that someone can help me out. I’d just finished a bearing job on a WF430 and on turning it on found out I’d connected up the motor wrongly, you know, mated the plug to the socket one pin out. Yes I can hear you all now, “what a kn*b”. Well I don’t suppose I’m the first to do it and I certainly won’t be the last. Anyway, after fitting it correctly, and trying it again, the motor now goes into instant full speed. Had a look at the board, no visible damage, but I presume I’ve blown a triac or something. It’s a mark 4 board as in EMW’s catalogue. Would it be the triac on the black heatsink that I will have to replace? Is it anything special or can I just use one from a scrap module? Can anybody help me out of this sticky situation?
    Cheers,
    AMS
    Re: Hotpoint WF430 blown pcb
    Come on guys, I can’t be the only one to do this? I removed and tested the triac on the black heatsink. Seemed ok but replaced it anyway. Am I barking up the right tree? Any electronic boffins out there that can help?
    #350274
    BobHope
    Re: Hotpoint WF430
    have you checked the tacho wires in the motor plug very common for them to snap internaly but look on on the insulation, try giving them a tug at the motor plug.
    Bob.
    #350275
    AMS
    Re: Hotpoint WF430
    Thanks for the reply, Bob. I will check them, but I do know that I made a c*ck up and have probably damaged the module. I was just hoping that someone would know the likely components on the board that are damaged and save myself the expense and time that getting one from EMW would incur. May just have to bite the bullet though and take it on the chin. Trouble is, EMW won’t re-open for business until tuesday.
    AMS
    Re: Hotpoint WF430
    I just want to say a big thank you to johnnyj who helped me out with this one. Problem solved and credibility restored with customer. You really do meet some top people on this site. Thanks again Johnny.
