Hotpoint WF440
  • #18290
    Module and 2 edge connectors are burnt. I’ve ordered a module from EMW but also would like to get the sections of harness for the water valves and the display panel. Could someone tell me the part numbers of these? Is there anyone who stocks these as I see Connect list them as special order? I suppose if they were going to take weeks to arrive I would be better just soldering the wires direct to the module.
    #178472
    Re: Hotpoint WF440
    Harness to valves & NTC is 1604539, not sure about harness to display panel, parts list includes ‘Harness Serial link, 1604540, it could be that, ❓
    What do you mean by ‘display panel’ this machine only has neon indicators as far as I can see.
    1604539 is apparantly in stock at Masterpart.
    #178473
    Re: Hotpoint WF440
    Thanks, I’ve not seen the machine, customer brought the bits to me. The part he says is for the display has 5 red wires, appears to have identical connectors both ends and plugs onto the end of the row of edge connector slots, next to the valves one. The board is marked J11 at that point.
    Masterpart lists MDA1604539 as special order.
    #178474
    Re: Hotpoint WF440
    There are two rows of neons, the ones down the side appear to be fixed directly onto the board ( difficult to tell from a diagram) and a row of five along the top of the console, no wiring harness shown for these but the only one in the list that does not make sense is the ‘Harness Serial Link’ ❓
    #178475
    Re: Hotpoint WF440
    Sorry, should have explained, this is the Indesit type module that lives in the bottom of the machine, not the WMA type where everything is behind the fascia.
    #178476
    Re: Hotpoint WF440
    Sorry for late reply, family problems. The Partfinder software has the distinction of being the most expensive and also the most error strewn piece of kit imaginable. 😥
    The picture diagrams do not show any wiring harness of any kind on the page that shows the dreaded Indesit module, down at the bottom. I tried to take a 3 phase one out of a 5 month old W/D last week and gave up. I managed to see that it had blown quite badly and advised them that even though the Indecent Company could not call out until 18 days later, waiting was still financially the best thing to do.
    On the diagram for the console facia and module, at the side are a couple of small bits that are supposed to represent the harness and numbers 142 to 152, unfortunately in the parts list it only shows numbers 142 to 149. I would still bet on the two numbers I have given you as the correct ones, all the others relate to other components.
