hotpoint wf440 flashing lights
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint wf440 flashing lights
  • #41117
    andysam
    hi just been to above washer and it only flashes when on a quick wash.
    the reduce creases, rinse hold, time saver all flash as well as on off button. it fills slightley and then empties then the flashing happens any ideas?
    #268859
    Re: hotpoint wf440 flashing lights
    They do say that “God helps them that help themselves” 😉
    Here you go.
    Error codes
    #268860
    Try page 3, works for me every time and I don’t read the Sun. 😉
    #268861
    andysam
    could you explain im a bit new to all this internet stuff. cheers
    #268862
    andysam wrote:could you explain im a bit new to all this internet stuff. cheers
    Welcome Andy,
    At the top of this forum you will see the thread “Known Error Codes” and the info you seek is listed within that thread. 😀
    For your greater convenience simply click here
    HTH?
    #268863
    Click on THIS link. Quite a bit to wade through but invaluble reading to help you use the forums.
    Also careful use of the SEARCH link will often bring up the answer you are looking for. Both of these links can be found near the top on any forum page.
