Re: Hotpoint WF440 – Noisy Spin
More likely to be a loose concrete balance weight than bearings on this model. One large weight on top of drum, another slung on the front of the outer drum, both prone to coming loose and causing noise. Would strongly suggest you get this attended to regardless of the source of the noise ASAP, don’t use it again until you have done so. Plug out if you intend to have a look or try the link below to see if we have someone in your area who can help.
Bearing failures on later Hotpoint machines have reduced significantly.
NB. Your machine has a five year parts guarantee so don’t go spending lots of money on bearing kits or the like, if in doubt send for Hotpoint.
