HOTPOINT WF445
  • #41720
    simonb
    fault with this machine is:
    ON/OFF SWITCH RAPID SLICKER (CONSTANT)
    TIMERSAVE CONSTANT SLOWER PULSATING ON/OFF LIGHT
    The machine can only be reset with plug out and back in, it will lock in a program but then only works for about 5 seconds or so, and goes into what seems to be a fault mode, i check through info closest i could get is on/off together with a combinationof the five left hand option buttons, now that makes it light 4down? fo1=motoirtriac? now im not too sure about that as the drum will turn briefly before fault mode operation.?
    checked brushes, no blockages, had a look around nothing visual
    #271129
    helo_75
    boards probably faulty mate
    it cant monitor the tacho, cos the triacs faulty, or the wires in the motor plug to the tacho have broken
    experience would suggest a pcb fault, if the wirings good
