Hotpoint WF540 new pump set up.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WF540 new pump set up.
  • #27218
    I went to a Hotpoint WF540 this morning, took 15 hair grips from pump filter.
    This is the first one I have seen with the Indesit type pump set up, the pump is front mounted, behind facia on the right with the bog standard Indesit pump & unscrewable filter. The motor is mounted to the left of the drum looking from the front, it does mean that access the main PCB is much better.
    I have been having a look on Partfinder and cannot see this set up in the WF540 list? I don’t have the commercial code to hand, perhaps that would shed some light.
    hotpnt
    Re: Hotpoint WF540 new pump set up.
    hi, there are 2 different models the WF540SC (screwed tub) & WF540WE (welded tub) bit of a pain when ordering as if you pick the wrong one all the pasrts are different
    #213105
    Yes, but none of them appear to show this later pump set up. 😕
    Oops, just found them. 😳
    helo_75
    if u lookk at the wf321.. thats the new set up, should help with diagram, theyre all coming now with the pumps at the front, which is good news, u dont have to empty a machine full of water on the floor to empty the pump nemore!!!
    #213107
    I think the access to the PCB with the motor shifted to the other side is a huge bonus.
    hotpnt
    yep, thats true, however ive struggled to pull out several machines to clear blockages only to find i didnt need to as the pump is at the front, how to makeyourself look a fool!!
    #213109
    Exactly what I did this morning, in a corner,under a fixed worktop, on a carpet, full of clothes and water I didn’t suss anything until I took the back off even though I wondered why the drain hose came out on the other side. 😆
    Jim
