Hotpoint WF541
  • #37050
    col-mac
    machine starts then fills and drains at the same time, on/off light flashes and also mini load and extra rinse lghts flash they are the 4th and5th lights down on the vertical set. the machine wont stop untill unplugged.
    any idea of the fault
    Cheers
    #253290
    Re: Hotpoint WF541
    Moved to correct forum, 😉
    Lights 4+5 is fault code F17. It is supposed to signify a door lock fault.
    However the Indesit electronics in these machines are known to be very unreliable.
    It could just be a faulty door lock but just as likely the main PCB itself.
    The door lock is not expensive so could be worth a try. Be sure to remove the mains plug if you intend to go inside the beast.
    GREENIEJIM
    I had a problem withone of these machines, where ALL lights on the front panel were flashing and no program could be selected, I took theboard out and noticed a 680uf 10V 105c capacitor blown on the main board, 30 pence for a replacement and an easy repair for DIY, 6 mths later machine going strong. Initial cheap components on board, typical mass production.
