Hotpoint WF541
  • #40852
    Mully
    Hi all,
    Can anyone help, I’ve been out to a Hpt WF541 today, fault code F03 (3rd & 4th lights) NTC fault.
    Checked Thermistor,wiring and mod connections, all OK.
    Tested M/C, as soon as starts F03 fault. But also fills and empties at same time, even on spin!
    Swapped mod for a S/H one put on spin did same.
    Thanks, John
    #267785
    nelson
    Re: Hotpoint WF541
    Hi John, I’ve had one like this before, I replaced the NTC which was faulty, but still got the same fault code and filling and emptying at the same time. I replaced the module with one from EMW and tightened the connections. That did the trick for me. good luck.
    #267786
    Mully
    Re: Hotpoint WF541
    Nelson,
    Thanks for your reply, I will get a recon mod from EMW and try that.
    John
