Hotpoint WF541 Aborting progs.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WF541 Aborting progs.
  • #41168
    Madmac
    This bundle of joy is around 2yrs old,fills for 15 secs or so & then aborts & drains. lights 2,3 & 5 are flashing which i understand should be fill prob, but i think this is bollox 😯
    Machine wont switch off once it faults unless you pull plug, think this means board wonky?? Any alternative views most welcome, thanks,
    Eddie.
    #269015
    Madmac
    Re: Hotpoint WF541 Aborting progs.
    Anyone?? f11 fault so it would seem, but board more likely?? I aint doin it if it is, these things are not worth spendin £100 on :eeek:
    #269016
    Your descriprtion of lights doesn’t fit with UKW codes book AFAI can see. f11 is drain pump isn’t it? But you said it drains. So I think I’d try in a p/sw.
    Mike.
    #269017
    Madmac
    Cheers for reply Mike, press sw was something i tried when i attended call, same result, its the fact it wont switch off on facia, plug needs pulled, that makes me suspect board.
    Prob just tell her to scrap it then, even with exchange board i have come to conclusion these things aint worth the hassle. 🙁
    #269018
    boselecta
    that is the conclusion I am coming to with these boards, getting alot of recalls or the same faults reoccuring that I have started telling customers to contact the manufacturer.
