hotpoint wf541 door lock
  • #66278
    abbots
    hi,
    door lock light not lighting up even though the door is locked.
    wont do any programs.
    tried a new door interlock, same problem.
    is it likely to be a PCB fault?
    if so top or bottom?
    any help much appreciated.
    john
    #363688
    Re: hotpoint wf541 door lock
    I always give the motor plug connections a good going over, even replace the motor plug for any doolock problems first, then it may be EMW time if no joy.
    #363689
    DDSDDS
    if wiring to motor is broken or the brushes are worn then this will cause a locked door but no door lock light its very common…never seen a board do that fault
    #363690
    abbots
    cheers,
    i’ll take a look.
    john
