hotpoint wf541 flahing lights
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint wf541 flahing lights
  • #59641
    IP
    hi, have hotpoint wf541p verticle lighits 1,2,3,4 are flahsing 5 is off, now ive read the fult code paperwork, and this fault says f15 which is dryer heater faulty relay, as far as i know this machine dosnt have a dryer on it, any ideas ??? or do these machines still use the dryer relary for something else ?
    #339032
    don
    Re: hotpoint wf541 flahing lights
    Moved to Trade Tech 😉
    Don
    #339033
    Micky 32
    Sometimes a dodgy element going to earth can cause the heater relay code. disconnect the element and run it to see if the code returns.
    #339034
    timdowning
    I agree with Micky32 but sometimes disconnecting the heater still gives the same fault as its looking for a circuit through the element.
    If the original heater is open circuit or low insulation then the best thing is to quote for and fit a heater.
    You can then run it on the fast wash which is ideal for proving the point.
