Hotpoint WF541 module clicking pump and motor stop/starts
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WF541 module clicking pump and motor stop/starts
  • #37275
    DPDOM
    Hi Chaps
    Hotpoint Wf541 on spin program the pump starts and stops rapidly and so does the motor. The module relays are clicking every few seconds.
    Today I fitted a module(EMW) the same thing happened.
    Found a bad earth inside molded plug so replaced but still the same.
    The motor will spin after a while but a bit rough.
    Disconnecting the pump has no effect on the relays clicking.
    No fault codes shown.
    Help before I hit the Bottle.
    Try again with other motor… I have had once this fault but also in washing program and old motor damaged also new module(motor relays).
    #254213
    DPDOM
    Re: Hotpoint WF541 module clicking pump and motor stop/start
    Thanks Baron.
    Yes it does it on the wash cycle aswell and relays don’t click while filling.
    so yes it looks like a motor fault even though my meter says all is ok.
    suspect a new machine on its way.
    David
