Re: Hotpoint WF541 – opening it up?
usually you can release the door-seal gasket and get your hand between the tub and the casing….can’t say if this applies to yours, though.
Always unplug first! switching off does NOT necessarily render it safe. also,switch off first , wait 1/2 hour to allow capacitors to discharge,then unplug and proceed.
If you just pull the plug, leave for a couple of hours before poking inside.
this electrickery can bite 😯
