Hotpoint WF541G Lights 1&3 flashing F10
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WF541G Lights 1&3 flashing F10
  • #51514
    Bernie
    I have just fitted a replacement EMW module, as all the lights were flashing. It washes and heats ok it’s when it comes to spin it does the distribute then starts to spin and I get lights 1&3 flashing F10 pressure switch not sensing.
    I have tightened the edge connecters on the board also changed the pressure switch still get lights 1&3 flashing.
    As this machine has a sealed tank and the pressure pot chamber is now part of that, how do you clean the chamber? I have tried blowing down the hose and there is a little resistance. I do live and work in a very hard water area.
    Anybody know any answers?
    Many Thanks for looking
    Bernie
    #308345
    helo_75
    oooh thats a tough one
    the only way i could even think of that is to take one of the paddles out, and rotate the drum and hope the hole in the inner drum lines up with the bottle and helps you clean it out
    worth a try
    i had the same problem with a candy go1482 and they wouldnt pay for a tub – write off!
    #308346
    Bernie
    Re: Hotpoint WF541G Lights 1&3 flashing F10
    Thanks for that helo_75 as you say it’s worth a try.
    I went to a 14 month old Hoover last week, sealed tank pressure pot chamber is now part of that too.
    Thanks again
    Bernie
