Hotpoint WF541P ERROR CODES
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WF541P ERROR CODES
  • #45056
    toby150
    Last week machine not emptying the conditioner in the draw, so I stripped it down and it was gunged up with mould. Also water not draining out of door seal and wifey said clothes still damp after a last spin.
    Draw now OK, Hole in drain hole in door seal was blocked. So far so good.
    I decide to take pump filter out of bottom right socket and it was clogged up so cleaned and put back. Now getting Mini Load flashing after last spin. Took out filter again and still doing it. My question is: are all thes faults related? How can I test pump if suspect?
    (ex enginneer but office equip not white goods) :rolls: 😆
    #283478
    helo_75
    top to bottom,top lightbeing one, what number light is flashing?
    probably a pcb fault, but ts best to be sure
    #283479
    toby150
    helo_75 wrote:top to bottom,top lightbeing one, what number light is flashing?
    It is Number 4
    About 10 mins ago we put it on a fast spin and just as I went to check your advice, it was number 4 button flashing along with the on off switch. Just outta warranty and just binned the £3 a month extra warrnaty on Labour. Dontcha just lerv it when that happens? 😥
    Cheers for advice
    #283480
    toby150
    It is Number 4
    Cheers for advice
    Wpould like to add to the above that the machine had finished its job and the clothes were dryer so why they are flashing? Also, if a PCB went would it not work at all? :rolls:
    #283481
    Don’t bank on it, we are talking Indesit electronics here. :rolls:
    Light 4 flashing suggests a motor triac fault and yet your motor is running.
    The boards on thes are just about the worst in the trade, prone to failure in all sorts of wonderful ways. 😥
