Re: Hotpoint WF541P very noisy when spinning
keep an eye on it – these were notorious for stripping the plasticy lugs on the drum. already had to drill through and bolt the weight on one machine, because otherwise the machine was a write-off… granted, it was a graded mode,l which i suspect its initial problem was therefore a loose weight, but all hotpoint did was add a bit of plastic padding filler, screw the screw in and send it back out. lasted 13 months and h/p didnt want to know when it went wrong.
