Hotpoint wf560
  • #22333
    timjam
    Hi, have an elderly lady who is having problems with door on this, the door glass seems to stick to the seal. anyone come across this ?
    #194509
    timdowning
    Re: Hotpoint wf560
    No, not had this problem. Has she tried leaving the door open in-between uses. It may be because she dosen’t use the machine often enough????????????
    #194510
    Re: Hotpoint wf560
    timjam wrote:the door glass seems to stick to the seal. anyone come across this ?
    She may be handwashing using Stergene or some other yucky substance?
    Do ask her exactly what she uses may give you a clue here? 😉
    #194511
    timjam
    Re: Hotpoint wf560
    Cheers! I will ask her when i go back, think it may be down to door left shut for too long
    Thanks 😀
    #194512
    HEADSTAND
    Re: Hotpoint wf560
    Hi get this problem quite often even on new w/m
    I lubricate the front piece of the door seal that comes into contact with the door seal with Vaseline or a silicone lubricant and hey preseto all fixed customer can repeat when ever it becomes difficult 2 open again . Also works on fridge door seals as well.
