The 4th light (mini) was flashing when I called, which is motor triac faulty. I sent the module to EMW, fitted the repaired one, which was OK for a couple of days.
Now the machine is completely dead. (no lights, no door locking, no nothing) There is a live and nuetral feed to the module, but it’s still dead. Can I assume another fault on the module, or can anyone help with another suggestion. Thanks
Thanks for the replies. Another repaired module from EMW cured it.
I think the problem was caused by a dodgy earth in the socket, one to look out for.
Question? there was a black earth wire on the motor which went to the mains supressor on a seperate terminal. Is this to give the invertor type motor a clean earth?
