hotpoint wf560 flashing reds
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint wf560 flashing reds
  • #36039
    davro
    hi folks . having aproblem with my 2 year old hotpoint wf560 around 3 weeks ago . on wash it just keeps going on and on it wont finish the cycle. have to cancel turn the knob to empty then do a rinse and spin which works normaly.
    the red lights which flash are 2,3,and 4 along with the on/ off switch.
    checked the drain pipe, the pump and the sump. the sump had lots of bits and pieces along with £6.33p in various coins[is this a record?] thought this might clear the problem but it hasnt. also noticed the water isnt heating up.
    looked in previous posts for similiar probs found none.
    any sugestion gratefully appreciated. thx davey.
    #249346
    helo_75
    2,3&4 is f07, heater relay
    faulty heater wouldnt show as a fault, moneys on pcb being faulty
    and youll need an eprom too
    need serial number, and which motor is on it to identify which one, but hotpoint charge £89 fixed price, regardless of what parts are needed, and to be fair, would work out as a cheaper option for you
    hope this helps
    #249347
    davro
    Re: hotpoint wf560 flashing reds
    wow !! thx for the swift reply helo_75.was hoping it might be something i could do myself[impress the wife]but hey thats life.
    1 thing though ,could you explain what eprom means or does. thx davey
    #249348
    helo_75
    yep
    the pcb on the machine is generic.. i.e it fits sevral in the hotpoint/indesit range
    the only thing that sets the machine is the eprom(a microchip), which plugs into the main pcb via a surface mounted chip holder, which then programs the pcb
    if youve never had a pcb fitted before, you will require one, if you have, then you can change it over
    the original ones on the factory produced model where smaller and surface mounted
    hope this helps
    #249349
    davro
    Yep .think i got that. so what you are saying is that the pcb onthe factory fitted is surface mounted and if it goes t!ts up you need a new pcb with a eprom which plugs in and programmed.
    so would this have to be a hotpoint engineer to do the programming as i suppose they wouldnt want just anyone using their software. davey.
    #249350
    helo_75
    well, always a grey area.. yes hotpoint have the software to program a blank eprom, but you can buy one ready programmed
    bit of a closed shop really, if you wanna keep costs down
    #249351
    davro
    ok helo_ thx very much . your swift reply and information has been most appreciated this is definately the place to be if you are stuck . cheers, davey
