Hotpoint WF620
  • #65615
    timdowning
    This machine has the 30mm bearings fitted. It is not a sealed drum & the sump is at the back like the WMA range.
    I dont want to be messing about with bearings & spider changes on this machine, so is it drum & spider 35mm type along with back half with 35mm bearings?
    Or can I use the WMA style complete tub and just swap the front tub section over so the door seal fittings are the same?
    Thoughts please.
    #361279
    karv
    Re: Hotpoint WF620
    if the 30 mm bearings are gone and you don,t want to change the bearings , your need a rear half/kit which come with 35 mm bearings and your need a 35mm drum support, most wma complete tub would fit on the rear as long as they were 35mm unless is a 7kg or washer dryer version this si just going from memory tho , you may require new heater and inner drum seal as well which comes with the kit version
    #361280
    Re: Hotpoint WF620
    Listed as standard 30 MM or 35 MM drum shaft and drum rear, not a 7kg model so 1603409 drum rear half would fit with a 35mm drum spider.
    There is a rear drum kit, 1605082 around £100 list price inc vat, not sure what it includes though.
    #361281
    timdowning
    Re: Hotpoint WF620
    Fitted the normal WMA complete tub assy. Thought I may have to swap the front tub section over for door seal fitting purposes as it is a WF not a WMA but didnt have to.
    Its always good fitting this tub assy as it comes with new belt, heater, thermistor & suspension pegs. Looks good on the invoice when you list all those parts!!!
