Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WF620 code?
- This topic has 8 replies, 5 voices, and was last updated 19 years, 8 months ago by
dopper.
July 22, 2006 at 4:19 pm #19346
dopper
Participantgot a wf620 as soon as its programmed h20 comes in display
checked codes pages is h20 a fill problem like on d/washer and how is it reset as cancel does not
cheers
paulJuly 22, 2006 at 5:00 pm #182710gegsy
ParticipantRe: wf620 code?
A make and full model number would help 😀
July 22, 2006 at 5:01 pm #182711Penguin45
Hottingpoint, Greg 😀 .
Chris.July 22, 2006 at 5:03 pm #182712gegsy
I’ll put me crystal ball away then 😆
July 23, 2006 at 2:39 pm #182713dopper
sorry its a hotpoint wf620
March 13, 2007 at 12:02 am #182714paulpaddison
Hi a customer of mine has the same machine. problem is it just wont work. says door. then when replacing the door lock door locked light shows but still the machine wont lock the door and when starting it says
f01 i know f11 is motor anybody got a chart of codes for this hoptoint WF620 or experienced this problem ? i checked everything even replaced the fused spur on the wallMarch 13, 2007 at 1:06 am #182715Penguin45
Drain pump ………..
March 14, 2007 at 2:16 pm #182716paulpaddison
forgot to mention hadto open the old door switch just to bypass it to get machine to think door was shut. then it displayed f01 have replaced pump and bypassed switch again but still shows the f01 weird thing is i also fitted a brand new door switch and still the machine thinks the door is open. also checked wiring back to the module.
could a power surge have upset the module? even tried the same type of board but off a machine with a diffrent display but that one just shows f09
any ideas ? or part ex on a new machine 😉March 14, 2007 at 2:40 pm #182717iadom
ModeratorRe: wf620 code?
paulpaddison wrote:forgot to mention hadto open the old door switch just to bypass it to get machine to think door was shut. then it displayed f01 have replaced pump and bypassed switch again but still shows the f01 weird thing is i also fitted a brand new door switch and still the machine thinks the door is open. also checked wiring back to the module.
any ideas ? or part ex on a new machine 😉Different board would show F09, wrong eeprom. Sounds as though the original board is goosed.
Codes are in the known Error Codes thread, same as Indesit WIDL machines.
