Can any of you guys out there help please? We have a rogue Hotpoint…. The machine shows “TEST” on all programs. It wont fill, pump wont activate. The only thing it will do is spin after a couple of minutes at the end of the test cycle. (Serial Number= 34118318). All display lights go across.
HOTPOINT washing machines stuck in “test” mode late models e.g. WF630G with display on fascia.
This is caused when user accidentally pushes on/off and start buttons simultaneously.
To exit test mode press start again > display goes wild>press start again>display settles down >
then press on/off plus start buttons simultaneously and hold for few seconds till display reads “D:end” or “D:off” or similar.
Machine should now function normally.
