hotpoint wf840
  • #27973
    petalpop
    i need the part number for a drum bearing + seal kit on the above machine
    connections says its a wma type but the bearings are a different size and the seals different
    cheers
    #216309
    ANDYVIVO
    Re: hotpoint wf840
    Hi Petalpop,
    Are they smaller than the standard WMA?
    Regards Andy
    #216310
    petalpop
    Re: hotpoint wf840
    yes the large bearing is the same as the small wma bearing
    the small bearing is 6205-2z
    and the seal is different as well
    it has a plastic drum pulley as well if thats any help
    #216311
    ANDYVIVO
    Re: hotpoint wf840
    Check 1604600, it is the only other kit I know off, it listed as a 30mm kit (the standard kit is 35mm from the shaft) 6205zz and 6206zz are the bearing sizes.
    Regards Andy
    #216312
    petalpop
    Re: hotpoint wf840
    cheers andy
    i will give them a try
