Hotpoint WF840
  • #29435
    bigkid
    Hi all,
    Anyone know if the thermister fitted to this machine is available seperatly.
    If not is it rated the same as the one fitted to the old hotpoint range WM’s and WMA’s etc.
    Tony
    #223079
    Re: Hotpoint WF840
    Not listed as a separate part. 😥
    bigkid
    Re: Hotpoint WF840
    Thanks,
    What about compatability?
    #223081
    helo_75
    isnt the wma thermister amp-tag and th wf idc?
    im sure theyre not interchangeable
    unusual for a thermister to go, its usually the heater relay sticking!!
    #223082
    bigkid
    Re: Hotpoint WF840
    I just need to know if they are interchangable electricly. Yes the terminals are different as you say but snipping off the plug and a couple of spade ends would deal with that.
    Relay is ok its the thermister terminal that is broken.
    Their resistances are similar which leads me to believe I can do a swap.
    Tony
    #223083
    Martin114
    Re: Hotpoint WF840
    Hi Tony, If the resitances are about the same I would see no reason why the spade type shouldn’t do the job. And probably more reliable with decent spade connectors rather than the flimsy idc plugs.
    #223084
    bigkid
    Re: Hotpoint WF840
    Cheers Martin, I was of the same opinion but thought it worth a mention.
    Tony
