Re: Hotpoint WF840 not pumping out
I took everything off, all hoses, the sump and removed the pump. Everything is clean as a whistle. I didn’t take the pump chamber off as I haven’t got the correct torx bits but I stuck a thin screwdriver inside to rotate the impeller which turns ok.
I suspect electronics as the pump seems to be ok now but now I’m getting error F-08 when I start a spin only cycle. I’ve done a full wash since and everything was ok.
I’ve had minor hiccups before with this machine and leaving it unplugged overnight usually clears them for some reason.
Thanks for the reply and I’ll post back if I have further problems.
