hotpoint wf860
  • #55545
    DDSDDS
    does any body know if there is a functional test programme for this machine similar to the one on the wma60 series
    also is there any way of finding out what software is currently on a pcb as i have a couple of spare working boards but i dont know if they are off the wf860 or the wt860
    thanks for any help
    danny
    #324268
    Re: hotpoint wf860
    i would talk to EMW
    they programme the boards so if you other board only needs a software change they will do it thay can also test you existing board
    DDSDDS
    Re: hotpoint wf860
    i have the smart card and reader so programing is not a problem and i do deal with emw when i am stuck its just i have a few good ones and wondered if there was a way of knowing what software was currently on it
    i can tell what the spin speed is using my rag but as for what drum / motor or hot and cold etc no clue so currently i am fitting the boards and reprograming them even though they may be the same software
    but the chances of having the right board with the right software i suppose is extremely low
    #324270
    helo_75
    the softare variant tends to be written on the label on the outer casing!
    #324271
    DDSDDS
    Re: hotpoint wf860
    would that be the 215007969.03 …..micro 2.74 number on the relay sticker?
    or the barcode sticker 3796503294loh7 ?
    #324272
    DDSDDS
    Re: hotpoint wf860
    sorry helo forgot to ask do you know if there is a test program of some description for these models?
    #324273
    helo_75
    unfortunately not
    the number on the pcb is
    (21)country of manufacture (50079) commercial code .these are on the label on the machine
    #324274
    DDSDDS
    Re: hotpoint wf860
    thanks
