Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WF860..F07 or not???
- This topic has 11 replies, 5 voices, and was last updated 14 years, 9 months ago by
iadom.
July 1, 2011 at 10:36 pm #63709
ModeratorHeres a weird one for you,
Called out to this machine apparently showing F-07, supposedly a heater relay fault.
I did not move the machine, remove any panels, just switched it onto a cottons 40° wash. It worked perfectly for 10 minutes or so.
She then said that the last time she used it she had set it to a Fast Wash 30° and it flashed up F-07 as soon as it had filled.
I did the same and lo and behold it did exactly as she said. ❓
I set it to a synthetics wash, a silks/special treatments wash and back to a 30° Fast Wash.
I had the machine plugged into my meter and on all of the non fast wash programmes the heater came on and it progressed normally, but when I tried it on a couple more 30° Fast Washes it aborted to F-07 as soon as it had filled.
The old grey matter was really starting to ache at this point.
I then set it to a 60° Fast Wash and it worked perfectly, then reset it to a 30° Fast Wash and beggar me, it then worked fine on that as well.
All of this happened without me touching anything inside the machine or moving it in any way.
How the hell do you try and fix a fault like this. :con:
ATM she is going to give it a run on normal programmes to see how it goes.
July 1, 2011 at 11:00 pm #354605leavemetogetonwithit
ParticipantRe: Hotpoint WF860..F07 or not???
Is it higher fill level on 30 deg washes?
Mike.July 2, 2011 at 7:43 am #354606Martin
iadom wrote:ATM she is going to give it a run on normal programmes to see how it goes.
It can only be a duff board then I guess? Mind you, Mike’s a bit of a whiz on heater relays so I hear. 🙂
July 2, 2011 at 11:29 am #354607leavemetogetonwithit
Heater relays are certainly under a lot of stress these days and it wouldn’t be surprising for it to start by going intermittent. The ones used are rated at 10 amps so are right at the limit of their spec. if not a bit beyond!
Having said that I tried changing them for F08 fault on a AWD12 once and it didn’t make any difference even though the contacts were pretty blackened.
Mike.July 2, 2011 at 6:17 pm #354608iadom
ModeratorRe: Hotpoint WF860..F07 or not???
leavemetogetonwithit wrote:Is it higher fill level on 30 deg washes?
No mention of different water levels in manual and it did work on 30° Fast wash the last time I tried it.
I did try and change a couple of these relays for F08 faults a year or two back without any success, gave up wasting my time on them. :rolls:
July 4, 2011 at 9:39 am #354609DDSDDS
i dont suppose it coulld be a water temp problem something like it is filling with warm water and causing it to get confused?
just a guessJuly 4, 2011 at 10:47 am #354610iadom
Naaa, it didn’t have time to register a temp, as soon as it filled it faulted to F-07 three times on Fast Wash 30°. I set it to a silks 30° and it worked fine on that.
Not had a call back yet so it appears to have worked for a few days at least. 😕
July 5, 2011 at 9:09 am #354611DDSDDS
gremlins
July 11, 2011 at 3:31 pm #354612Micky 32
I have seen an element with an earth leak cause the relay fault code.
July 12, 2011 at 8:47 am #354613DDSDDS
that rings a bell micky i have had that too randomly throughout the cycle on wt960
July 12, 2011 at 8:51 am #354614iadom
No call back yet after 11 days. 😕
The heater would have been near the top of my ‘usual suspects’ list, time will tell. 🙂
July 12, 2011 at 6:15 pm #354615leavemetogetonwithit
iadom wrote:No call back yet after 11 days. 😕
Give it time. 😆
Mike. -
