hotpoint wf860p f10
  • #39862
    mikethemechanic
    hello there problem is appliance fills starts turning then flashes up f10 ive been told its a pressure switch fault but that tests ok tested the heater and checked the sump for blockages do the boards go cant see anything blown
    is this a pressure switch error?
    any advise???
    regards
    mike
    #263913
    Re: hotpoint wf860p f10
    Moved to Trade Technical, you stand a better chance of getting an answer here than in the public forums. 😉
    When you say you ‘have been told’ did you not check in the Known Error codes thread, or have you not yet purchased the Fault code bible?
    F10 is supposed to be pressure switch not sensing, the switch itself is very prone to failure but it often comes down to a faulty PCB, they also fail for fun. 😥
