Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WM 52 trips electrics
- This topic has 4 replies, 3 voices, and was last updated 21 years, 5 months ago by
admin.
November 12, 2004 at 12:35 pm #6796
KeymasterHi, I have a Hotpoint WM 52P serial number 56128133 washing machine that trips out the electrics. I am an an engineer by trade but automotive, so I have reasonable knowledge of things mechanical/electrical. Spoke to local engineer who told me these machines suffer with motor problems (particually brushes/armature) and possibly this has caused the timer/circuit board to fail and best to cut my losses and invest in a new machine? I have had the motor tested using a friends Megger and all checked out OK, brushes armature and bearings in good condition. So not sure if the motor theory comes in here. I have tried disconnecting the motor and still the machine tripps out almost as soon as the timer moves to try to do something (does it on any setting including economy). I stripped out the front of the machine and tested the heater/wiring for continuity all ok. No obvious signs of damage, burnt tracks etc on the circuit board. I’m quite capable of fitting a new timer/circuit board if I could be sure this is the only problem. Any suggestions or advise would be appreciated as it’s become a bit of a challenge.
November 12, 2004 at 1:00 pm #119651Dave_Conway
ParticipantRe: Hotpoint WM 52 trips electrics
It’s highly unlikely the timer/control unit will blow the trip, I would check the heater again with a megger 😉
November 12, 2004 at 1:00 pm #119652Martin
Mark,
Bad news I’m sure on this 😥 I suspect what has happened is the the Door Interlock has shorted out and taken with it the Timer/Electronic Control Board. (Easy check…when you rotate the Programme Dial, if it appears to be slightly stiff in places…thats the give away 🙁 )
Physically the PCB will have blown tracks near the front top end of the board as you look at it. Plus the white plastic water shield will be blackened in the immediate area!
Hopefully I’m wrong…fingers crossed 🙂
November 12, 2004 at 1:41 pm #119653admin
KeymasterRe: Hotpoint WM 52 trips electrics
Thanks guys, will check the timer knob/pcb board and megger the heater. The red door lock light does come on when you switch on the machine. I presume the door can be opened at any point if the interlock switch has Failed?
Didn’t have a plastic water shield fitted and saw no burn marks on the lid or machine casing.
Cheers for the quick response!
November 13, 2004 at 7:15 pm #119654admin
Mark
If the timer is faulty why not get it repaired I was given a couple of places by the lads on here one being Quality Electronic Repairs on 01900 67913 who do a postal service their url is http://www.qer.biz just in case you need it.
Roy -
