hotpoint wm 61
  • #15097
    mowerman80
    Went to this washing mahine today no spin. First thing i check is brushes they are fine turned out it is the fuse in the motor had blown. I changed that and checked the comm etc all ok went into spin etc ok then when it started to slow down after finishing spin motor went bang and blew fuse again. Any ideas as i used to be a hotpoint engineer and never had this problem.
    #162013
    Re: hotpoint wm 61
    mowerman80 wrote: the fuse in the motor had blown. I changed that ……..blew fuse again.
    What fuse? Is this something I don’t know about? Is it the FHP motor then?
    Only thing I know of is a t.o.c. in old type motor which is self resetting I thought. 😕
    Very unusual fault whatever it is you’re referring to. Sounds like time for a new/exchange motor. Some s/h ones have been going on e-bay pretty reasonable if you’re out of stock.
    Mike
    #162014
    funkyboogy
    Re: hotpoint wm 61
    also check timer…if motor went with a bang,it can take out timer…you dont wnt to quote for motor,go back and discover timer faulty also ???
    #162015
    Re: hotpoint wm 61
    Armature, TOC and brushes will sort it. You’ll have to have an ARM20 and TOC17 from a Qualtex agent – you can still do the gen carbons. Or a new motor, but not many want to pay that much on a machine that age these days.
    Cheers,
