Hotpoint WM 64
  • #16514
    robbra
    Have replaced the suspension on this and now when pressing start the pump grumbles intermittantly but nothing else. when pressing cancel pump sstill grumbles bot the board tinkles.I think its a triac which is on the bottom of the board, the contacts switch quickly but as I say nothing happens. On switching of and on a quick burst of water comes in then stops and the motor then runs. Pressure switch seems ok.Wish I could have tried the m/c before but drum was on the base.
    TIA
    Rob
    Hope you can understand this
    #170183
    Re: Hotpoint WM 64
    Have sent you an e-mail which may be of some use.
    robbra
    Re: Hotpoint WM 64
    Thanks Jim
    Will try this tomorrow
    Rob
    #170185
    Re: Hotpoint WM 64
    Let us know how you get on, the ‘stuff’ I sent you appears to have helped cooky2 with his WMA64 problem about 20 posts down. 🙂
    #170186
    robbra
    Re: Hotpoint WM 64
    Daft ain’t it. Go back today and the whole thing works perfectly. Dunno why and thankful that it did. Will keep test proceedure as bound to need it again sometime.
    Thanks again
    Rob
