Hotpoint WM12 won’t complete program
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WM12 won’t complete program
  • #43272
    lordswood
    My parents WM12 stopped before the final spin in it’s program.
    They thought it might be a belt problem, but eveything’s OK there. However the neutral wire in the plug was burnt and I think the fuse had blown. They sorted that, but on testing it stopped again at the same point.
    I think it sounds like a PCB fault, but would that cause the burnt wire and blown fuse? Anyone have any ideas?
    Update.
    My father just phoned to say that the timer is clicking through the program , but the machine’s doing nothing after it has halted.
    #276692
    Washman
    Re: Hotpoint WM12 won’t complete program
    HI
    Check motor brushes.
    Switch off and plug out first.
    Mike
    #276693
    lordswood
    Hi Washman.
    My father checked the brushes, they’re OK.
    Drum was turning and spinning OK ’til it stuck at the same point in the program several times.
    #276694
    helo_75
    faulty water valve?
    #276695
    lordswood
    Not the valve helo_75, it fills and empties OK.
    #276696
    helo_75
    theres more than one valve you know
    werent you aware theres a single valve just for the conditioner? or does the fact that it fills mean its ok?
    ah well
