It is supposed to need a new motor plug kit, it used to come with the motor but is now listed as a separate part.
You can plug in the old motor plug but you need to be very careful.
Snip off the lugs on the connector block and then identify the two wires that go to the tacho on the old motor and make sure that these go to the tacho on the FHP motor. Its usually a 180° switch round.
