hotpoint wm22 constant filling and draining, not syphoning
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint wm22 constant filling and draining, not syphoning
  • #75751
    Washdisher
    Ancient Hotpoint washer.
    During conditioner rinse cycle, it fills to a point below door glass and then stops filling, then simultaneously, the drum rotates (about half a revolution) and the drain pump kicks in for about four or five seconds. Then the whole cycle repeats again.
    Goes on like this for some time, but eventually carries on as normal. Wouldn’t mind but I’m on a water meter, and it’s also a waste of a precious resource.
    Timer stuck perhaps?
    #396019
    Re: hotpoint wm22 constant filling and draining, not syphoni
    from what i remember thats normal for that machine. its getting on a bit now and water and energy saving are modern ideas
    johnnyj
    They called it step cooling reducing the temp of the water to prevent creasing rather than pouring cold water onto hot clothes..
    #396021
    Washdisher
    Thanks Dave and Johnny, you learn something new every day. I’ve recently replaced the bearings so I’ll hang onto the dinosaur for a while longer.
    #396022
    that dinosaur is still better than the modern hotpoint they are junk dont touch them
