Hotpoint WM22 – pecker arm
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WM22 – pecker arm
  • #38172
    MickGeorge
    Hi folks
    After a pecker arm for the above but found out it is no longer available – it’s the inboard type that rests on the motor shaft and not on the belt.. (part no 1601775)
    Anyone done a mod on these (fit the old type as the old type are still readily availible??? as this seems one possibility)
    Any suggestions apreciated – can tie the pecker arm up so door can still be opened but obviously not a solution as door can be opened on spin and a great danger..
    Seems stupid to right of m/c just for this as m/c in good working order..
    Mick
    #257939
    Re: Hotpoint WM22 – pecker arm
    If you do fit the other type you will also need a different cable. Have you checked for pattern ones? I see Connect still list 1601699.
    #257940
    bzz67
    yes i have got one, but i would not tie up the old one for now, its a bit dangerous.
    give me a call on 01884 254760 and will put it in the post asap
    £14.00 inc p&p
    #257941
    MickGeorge
    Got the arm.. thanks bzz66… One happy customer…
    Mick
    #257942
    bzz67
    MickGeorge wrote:Got the arm.. thanks bzz66… One happy customer…
    Mick
    No problem Mick.
    cheers
