Re: Hotpoint WM25 shock absorbers
There are several ways to achieve this, I have always managed to do it by just removing the front panel, it is quite physically demanding, a bit of a wrestling match at the same time. Some people do it by lying the machine on either side, still awkward. At the other extreme end you could remove the complete drum assembly to do it, no hard and fast rules TBH.
To do the job correctly you should use THIS kit, includes all the bits you will need.
