HOTPOINT WM32S
Viewing 6 posts - 16 through 21 (of 21 total)
  • #108681
    Using an old Torx bit and an extension, give the heads a right whack! That usually cracks them ready to unscrew.
    Penguin
    #108682
    cornwell40
    Re: HOTPOINT WM32S
    Did that, and again, and again. Judging by the pulley nut, I think the guy who assembled the machine had shares in loctite…..
    Tony C
    #108683
    Tom
    Re: HOTPOINT WM32S
    Am i missing something or does the spring sit onto the inner bearing collar.
    😕 This seems a strange arrangement to me too; seems certain for a short life for the seal and bearing. I cant rember who / where but I think I heard of a modification for the WMA bearing assembly.
    Any comments / help welcome.
    😀 😀 The ongoing technical forum I find very helpful and interesting. Many thanks to all.
    tom
    #108684
    Re: HOTPOINT WM32S
    cornwell40 wrote:
    1. Are the hex screws welded into the spider?? broken hexes, broken drills, empty can of wd40 and still they laugh at me
    Not really but they might as well be, only solution= New Inner Drum
    cornwell40 wrote:2. When I finally got the split collar out (the drilled groove method) and the new bearings in, put the sprung seal in place and ..Hey Presto Stuck solid bearings. Am i missing something or does the spring sit onto the inner bearing collar.
    The bearings are aligned with a factory press, which is difficult to duplicate correct bearing set-up without such a tool. The spring does indeed sit onto the bearing collar (acts as a static discharge contact)
    Best replace Drum Assembly in future I reckon. As penguin rightly points out (which I have since discovered) the Drum Assy carries a 5 year guarantee for Merloni to replace on a Labour Only basis. Left them have the problem!
    There’s a new range of Hotpoint W/M’s coming out very soon, God ‘elp us!
    don
    Re: HOTPOINT WM32S
    martin wrote:There’s a new range of Hotpoint W/M’s coming out very soon, God ‘elp us!
    Quite right I have recieved this morning info regarding these from Hotpoint. 11 new models all starting with prefix WF and new colour options ie Graphite, Polar,Aluminium and Sandstone ( which looks like a replacement for natural Linen) but I could be wrong as I have only seen a picture 😉 . Prices look similar to current models so i do not expect any better build factor but who knows. Spin speeds from 1000 to 1600 RPM all now take 6KG load. No mention yet as to when these will be available but I will keep you posted so you can keep an eye out for them.
    Regards
    Don
    #108686
    don
    Re: HOTPOINT WM32S
    I have just recieved new laundry catalogues it seems I was right Graphite replaces Zircon Silver and Sandstone replaces Natural Linen.
    release dates are washers, Aquarius, aquarius + and Ultima due April 04.
    First Edition May 04. Washer Dryers July 04. Vented dryers May 04. Condenser dryers August 04. 60cm dishwashers May 04 and 45cm dishwashers June 04. Fascia panel looks slightly different as does the door. Will have to wait and see them in the flesh to really comment.
    Regards
    Don
