Hotpoint WM36 E15 error code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WM36 E15 error code
  • #14202
    satman
    Last couple of days my washer has givrn an E15 eror whilst spinning, Took back off last night and i noticed that the flexi rubber tube between the pump and drum was collapsing whilst on spin cycle.
    I have checked the pump and there is nothing in there that should not be.
    #158581
    Dave_Conway
    Re: Hotpoint WM36 E15 error code
    It’s blocked in that hose between the drum and pump by the sound of it, the pump “suction” is causing the collapse due to the restriction.
    A sock is most likely 😉
    Power off when checking :zap:
    #158582
    satman
    Thanks Dave you were spot on.
    Stripped of pipe and guess what was in the plastic trap filter.
    The remnants of a spiderman sock..
    Have a merry christmas.
    Mark 😛
