Hotpoint wm52
  • #64399
    ian07
    I have an oldish hotpoint wm52 (second hand to me) & its stopped draining after a wash.
    It will drain a bit of a dribble out but not all of the water,which then causes it to stop spinning.
    I took the back off & took the grey pipe going to the pump to check for blockages & then the drain pipe from the pump,all clear.
    I have scooped the left over water out & the machine will spin as normal.
    Can anyone help or advise me please..?
    Cheers
    Ian
    #356931
    Re: Hotpoint wm52
    Is the drain pump actually running, have you removed the black rubber ‘T’ shaped hose from the drum to check the cointrap/filter?
    #356932
    ian07
    Re: Hotpoint wm52
    Hi,yeah the pump is running as far as i can tell,i will have to take that ‘T’ hose off,not checked that yet.
    Cheers,i will report back on what i find
    #356933
    ian07
    Re: Hotpoint wm52
    Hi,back again
    Ok all fixed now by the look of it,after removing the cointrap/filter i removed a 5p,10p,20p,a button & some blue fabric stuff.
    Drains fine now
    Thanks again to a great forum
    Ian
