Hotpoint WM52 bearing & shaft removal
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WM52 bearing & shaft removal
  • #47412
    lowrider
    Can anyone give me some advice on how to replace the bearings and shaft on my WM52 first edition .
    I do have some mechanical knowledge , but would welcome any advice and tips !
    Cheers !!!
    #293373
    Re: Hotpoint WM52 bearing & shaft removal
    Not sure if it’s in the latest edition but this job was described in the Haynes manual for washing machines. Basically you remove the cabinet front, remove the tub front which is held with spring clips, remove the rear pulley locknut and turn the pulley to unscrew it from the shaft, knock the shaft through with a mallet and remove the inner drum. You can then drift or press out the bearings and bolt a new drum support to the drum.
    #293374
    lowrider
    Cheers , for the info , got the parts this morning , so at the weekend I will have a go at replacing them , thanks again !
    #293375
    Ideally you should also replace the large black drum front seal. Re using the old one wll leak in most cases.
