hotpoint WM52 first edition.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint WM52 first edition.
Viewing 13 posts - 16 through 28 (of 28 total)
  • #258570
    MRKB
    Re: hotpoint WM52 first edition.
    Hi whats the conditioner valve
    #258571
    The cold fill valve is a double valve, one side fills for all the washes that use cold water, and all the rinses up until the last rinse. The last rinse fills through the cold valve then switches over to the conditioner valve to flush in the fabric conditioner.
    #258572
    MRKB
    thanks, I will check it out , remove pipe and check tray, replace and observe in use see what happens or not happens, determind to fix it :rolls:
    #258573
    Just take the small white ‘thimble’ out of the conditioner compartment, run on cycle but don’t open the drawer whilst it is filling or you may divert water from the other valve into the conditioner compartment. If the compartment is empty when the machine sticks then you have a faulty conditioner valve.
    If the valve is working then the compartment should be full of water when run without the small syphoning tube in situ.
    MRKB
    cheers jim, will have a go tomorrow, bit late to start again now 11pm
    #258575
    If it turns out to be the valve, THIS is what you need.
    MRKB
    Hi its me again, today new wash load in machine, setting on E normal wash, lid removed from machine to see whats happening or not happening with water fill from double inlet valve, waiting and watching for it to stop where it stopped before ( rinse & spin cycle ) umm it did not stop it completed the full wash cycle, BUT I did notice that the inlet pipe for the conditioner drawer did not opperate but yey it did not stop the cycle from completing. So at least I know I do need a new double inlet valve fitting, This is the 3rd wash attempt after fitting the new brushes is it possible that the brushes have bedded them selfs in and solved the stuck cycle porblem :rolls:
    Mr KB P.S. excuse my spelling.
    #258577
    Badly seated brushes would cause the machine to stick mid cycle.
    You will only need to change the conditioner valve if it is not actually taking the conditioner into the machine.
    #258578
    MRKB
    Hello again peeps, all was well untill last week 9th sep when washing machine motor decided to pop out one of its brushes and damaged it badly,anyway bought some new ones ( genuine ones ) replaced them both pluged the machine back in turned power on machine selected a wash cycle switched it on, it put the water in then did a few rotations of the drum and blew the fues. ok so replaced fues started again it put water in again but NO rotation of drum at all. and thats the problem, please help 😀
    #258579
    You may have blown the internal motor overload. Sounds as though the commutator has lost a segment.
    Looks like new motor time, could possibly have also damaged the control timer. 😥
    MRKB
    humm will take motor out and check it over, but if the control timer is kaput it may not be worth mending. :rolls: :rolls:
    #258581
    MRKB
    Hi peeps, took the motor out today and the commutator looks ok ,gave it a clean while I could, made sure the brushes worked and fitted. refitted motor and tryed it again with no joy. SO, has the motor got a thermal trip inside that will have blown ? and can it be replaced, the timmer on the machine seems to work ok.
    #258582
    If it has blown the thermal trip then there is very strong possibility that the armature is goosed.
    Have you meggared the motor including the armature for earth leakage?
