HOTPOINT WM52 KNOCKING NOISE WHILST SPINNING
Home Forums Public Support Forums Help And Support Washing Machine Help Forum HOTPOINT WM52 KNOCKING NOISE WHILST SPINNING
  • #57540
    lowrider
    My hotpoint WM52 has started to have an intermittent knock whilst on its last spin , its not always there , and only does it with wet washing .
    I have just bought a suspension kit which I’ve fitted that I purchased from whitegoods , so i don’t think its that unless something is faulty .
    I also fitted a new spider and bearing last year as well .
    Please can you advise .
    #331490
    nigegt
    Re: HOTPOINT WM52 KNOCKING NOISE WHILST SPINNING
    Unclip the front plate and look at the seam that runs along the inner drum. It can become miss-shapen and catch the outer tub when the drum is loaded. Take the drum out and hammer it flat if it looks bowed at all.
    Nige
    #331491
    Also check the bolts to both the small upper and very large lower concrete balance weights for tightness.
    You can also get a knock if the rear bearing is slightly loose inside the housing.
    #331492
    lowrider
    Checked drum , all is fine there , but there was a bit of play in the nuts that hold the weights and quite a bit on the one that holds the bearing .
    The Mrs did her washing , and happy day’s , no more noise .
    A Big thank you guy’s , yet again . 😀
