Re: Hotpoint WM52 Motor
C00118057 is correct motor, you don’t really need any conversion kit, you can plug the original motor plug into the FHP motor. Just make sure you identify which two connections on the motor plug go to the tacho on the old motor and line these up with the tacho connections on the new motor.
On the other hand, why not just fit an ARM20 armature from Qualtex and new brushes, still fit these on a regular basis, rarely ever fit a motor.
