When I start the machine it works for only a few seconds then stops. If I leave it a short while and put the plug back in then exactly the same happens again. Can anyone please advise me
regards
Strange, not usually caused by a motor brush problem but it wouldn’t do any harm to check them first.
Does the door stay locked even after it cuts out?
With the mains plug removed you could also check all of the wiring harness paying particular to where it passes the large concrete balance weight, low down at the front.
If all that checks out then it points to a PCB fault.
