We are having a few problems with our Hotpoint WM52 First Edition 1000, firstly the drive belt keeps coming off, although this is relitively easy to put back on it is a bit of a pain?
Secondly and a bit more importantly the washing machine keeps tripping the electrics.
When you start a cycle the washing machine fills until the water reaches just under the level of the door at which point it blows the electrics. It works on the spin cycle but the same happens on the rinse cycle.
Could this be a heater problem? or is it more likely to be water leaking in to/on to something it shouldn’t, or something else entirely.
It also sounds like the water is draining out the back as it is filling.
On top of this it is making a lot of noise on the spin cycle which I am guessing is a problem with the bearings?
Any help would be much appreciated.
Cheers
L.
