Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WM52 Trips house RCD mains
- This topic has 6 replies, 2 voices, and was last updated 18 years, 3 months ago by
Bosh.
January 7, 2008 at 6:33 am #33461
Bosh
ParticipantHi,
Girlfriend has a Hotpoint First Edition 1000 WM52 which Trips all the house electrics RCD when selecting a wash program.
It starts for about 1 second you can hear water pumps running then wham, it just trips out the mains RCD.
Any ideas please?
January 7, 2008 at 9:48 am #238802iadom
ModeratorRe: Hotpoint WM52 Trips house RCD mains
No one specific cause of this. Most likely candidates are the main motor, motor wiring harness, heater and door lock. The only way to trace the fault is by individually checking every component and wiring for earth or insulation faults with a meggar or multimeter. I assume you mean you can hear the fill valves running, the drain pump does not run on start up on this machine.
January 7, 2008 at 1:15 pm #238803Bosh
ParticipantRe: Hotpoint WM52 Trips house RCD mains
iadom wrote: I assume you mean you can hear the fill valves running,
Yes, that’s correct, just briefly before the power trips off.
Thanks for the pointers, I will have another look with a multimeter later in the week.
January 15, 2008 at 8:09 am #238804Bosh
When I disconnected the motor, the machine worked without tripping the power.
Does this mean the motor is faulty, and can I now look for a replacement?Thanks.
January 15, 2008 at 9:39 am #238805iadom
Sometimes you will get away with new brushes and a clean up of the commutator, it is also possible to replace the armature and brushes, failing that its new motor time.
The problem is, the more times you have allowed it to trip out, the more likely it is to have damaged the commutator, it doesn’t sound as though it has taken out the motor overload yet so you may get lucky with new brushes.
January 29, 2008 at 12:42 pm #238806Bosh
I replaced the motor and the machine is working fine now.
There were several short circuits on the old motor when measuring from motor case to the terminal block connectors.
Thanks for all help.
January 29, 2008 at 5:20 pm #238807iadom
Thank you for coming back to let us know the outcome. 8)
