Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WM52P
- This topic has 6 replies, 4 voices, and was last updated 16 years, 7 months ago by
jackster.
September 3, 2009 at 9:45 am #48291
jackster
ParticipantI have a problem with this machine in that it originally didnt spin.Replaced the Brushes (totally shot) and now there is no motor action at all. The motor megas ok, I have checked all wiring & connections. I am convinced there is a fault in the wiring as after messing, pulling and prodding it will start to tumble for a few minutes then stop again but I just calnt find the offender! Any ideas??
September 3, 2009 at 9:55 am #296188iadom
ModeratorRe: Hotpoint WM52P
Does sound like a bad connection, have sent you the wiring diagram.
September 3, 2009 at 9:58 am #296189leavemetogetonwithit
ParticipantRe: Hotpoint WM52P
Well you could pull off the motor plug and the plug that fixes to the module and firmly connect a test lamp (faster to read than most digital meters) using male 1/4″ spades
at each end of each wire in turn and wiggle till you find the intermittent connection. It’ll be the motor plug itself (I mean the one that plugs into the motor) most likely cause that’s the one that gets jiggled about. Just rewire using insulated amp tags.
Mike.September 3, 2009 at 10:08 am #296190iadom
leavemetogetonwithit wrote: Just rewire using insulated amp tags.
Or use the special pliers provided by Hotpoint to refit the wires into the Pressac plug, thats assuming you have a pair of course. 😉
September 3, 2009 at 10:18 am #296191leavemetogetonwithit
iadom wrote:
Or use the special pliers provided by Hotpoint to refit the wires into the Pressac plug, thats assuming you have a pair of course. 😉They haven’t “provided” me with any. Think I’d probably say no thanks if they wanted to. 😆
Mike.September 3, 2009 at 11:15 am #296192Martin
leavemetogetonwithit wrote:Think I’d probably say no thanks if they wanted to. 😆
Connect want £120 for one if you fancy a Hotpoint ‘Wire Insertion Tool’ Mike? Check one out Hotpoint Part No: 570108
At that price they must be queuing at the door to buy one…..:rotl:
(Think I might flog a spare one I have on ebay in that case…..£100 maybe??????? – bargain :snigger:)
September 3, 2009 at 4:10 pm #296193jackster
Replaced motor plug with new connectors and sorted, thanks for all your help.
